Conversion of Driving Lights to operate on Low AND High beams!
Old 03-28-2007, 08:22 PM
Sheep's Avatar
Sheep
Sheep is offline
Default RE: Conversion of Driving Lights to operate on Low AND High beams!
ORIGINAL: mistermooster
I noticed this light situation shortly after bringing my '07 home, refering to not being able to have the spots and the high-beam on at the same time. Didn't like it, but do you think it was to protect the circuits from overload?Why else would they wire it this way?
Pretty sure its done for legal reasons. Some states don't allow passing lamps and highbeams to be run at the same time so HD rather thanoffer an option turnsthe option off for everyone.
  #32
Old 03-28-2007, 08:27 PM
TexasRedneck's Avatar
TexasRedneck
TexasRedneck is offline
The shop manual has full schematics in the back. Yeah - ah actually traced the entire circuit ta be sure....
  #33
Old 03-28-2007, 08:39 PM
Dave_E's Avatar
Dave_E
Dave_E is offline
Thanks for the post. Ya know, I think I may do this. I have to take the brains out of the RKC again, Harley is warranting the new touring bars I just put on...had some cosmetic blemishes I didn't see in the plastic when I picked them up at the dealer. This will go good with the aux switch housing on the LH grip I just installed also.
  #34
Old 03-28-2007, 08:59 PM
alazlo's Avatar
alazlo
alazlo is offline
I have found that your basic crack torch type lighter, which an be purchased at just about any convenience store, works great in lieu of a soldering iron...
  #35
Old 03-28-2007, 11:34 PM
TexasRedneck
True. Ah've also found them crack torches ta be EXCELLENT at startin' other stuff on fire, an' meltin' plastic when ya fergit ta watch the flame.[:@]
  #36
Old 03-29-2007, 08:08 AM
questor's Avatar
questor
questor is offline
Good morning
I am confused, yea that is normal. Do you have to remove the faring to peform the wiring conversion or the ACC switch?
  #37
Old 03-29-2007, 08:25 AM
jbhawley's Avatar
jbhawley
jbhawley is offline
Yes, the fairing will need to be removed as that is the easiest/only way to get to the plug in connector to unplug the switch dash from the fairing wiring harness. ALso the switch dash and ignition switch will need removal.
  #38
Old 03-29-2007, 09:16 AM
TexasRedneck
NO - you do NOT have to remove the fairing to perform this mod. You'll pull the ignition and dash - but that's it. The plug module is accessible as you pull the dash free.
  #39
Old 03-29-2007, 09:27 AM
jbhawley's Avatar
jbhawley
jbhawley is offline
sorry about that TR. I have pulled my fairing off frequently in the past couple months, that i dont even consider there are other ways. I did say EASIEST...LOL. Well, might save me a few minutes next time. Thanks.
  #40
Old 03-29-2007, 09:31 AM
TexasRedneck
C'mon JB - ya KNOW you wuz figgerin' ta have him do it jest fer practice...<G> Dunno - because on mine, as ah started ta move the dash the plug came right into position fer easy access w/o havin' ta remove the front fairing - even though it was already off. At that point, most everything wuz off the bike...
Quick Reply: Conversion of Driving Lights to operate on Low AND High beams!
