BELT/TIRE Rubbing
BELT/TIRE Rubbing
Morning.., I purchased a 03 EG when I changed out my rear rim from stock to 18...., the could hear the belt rubbing the tire. when pushing it back/forward.... just recentlt when I had the bags off, cleaning and inspecting I can see where the belt has been rubbing the tire..I may have ran it 500 miles. the tire is a 150/70/18. Would a smaller tire correct this..., if so what size. Or do I have another issue. The rim is straight.
If you verify all is installed right, you can always buy a pulley spacer. Drag Specialties carries them so any dealer/shop should be able to get it.
Rear wheel spacers would be hard to mix up. Wide one on pulley side, narrow one on brake side.
Zach
Zach
