I am installing the Timkin bearing in my 07 RG, does anyone have a suggestion of what bearing to use on the right side? The parts book shows both bearings to be the same part number, so would the Screaming Eagle lefty bearing be an identical fit and would it be a better bearing to install in the right case? Or is the stock one adequate? The crank is weldeded, plugged and balanced and should be pushing close to 120/125ish. Thanks
