06 fl reg recall/s.b
Harley-Davidson Motor Company, Inc. has learned that certain
2006 Touring model motorcycles were assembled with a
potentially defective voltage regulator.
In the interest of customer satisfaction, Harley-Davidson has
elected to replace the old style voltage regulator (P/N 74505-
06) on all affected motorcycles.
This effort also includes the replacement of all affected P&A
chrome voltage regulators
RE: 06 fl reg recall/s.b
Bulletin came out 14 Mar 07. Certain 2006 motorcycles. Also includes the repalcement of all affected P&A chrome regulators (p/n 74622-06) installed on certain CVO models. Certain models built beween 8 Nov 05 through 28 Mar 06. The black affected regulator is stamped on the back/or engine side of the regulator and is 74505-06. The chrome is stamped on the left/inside of the mount post. This recall can also will cover over the counter regulators.
1. As some motorcycles may have already had the voltage regulator replaced under warranty, and would not require replacement under this program, always check the four digit date code:
a. On stock (black) voltage regulators, the part number (74505-06) and date code are stamped at the rear (just in front of the oil filter).
b. On P&A chrome voltage regulators, the part number (74622-06) and date code are printed on an adhesive label fixed to the inboard side of the right leg.
NOTE For internal purposes, actual part number on the label may be 74623-06 instead of 74622-06.
2. If the date code is between 4205–1406:
a. Replace the stock (black) voltage regulator with that provided in the wave shipment of replacement part kits (P/N 94503).
b. Replace the P&A chrome voltage regulator with that provided in the ordered replacement part kit (P/N 94527).
NOTE The last two digits of the date code is the year of manufacture, while the first two digits is the week of the year.
