Brake light/ turn signal
I have the Kury setup on my 05 RK Custom. Front and rear turn / run brake and LED Brake light. They are bright in the day and brighter at night and the 3 flashs of the brakes when you hit the pedal makescagers back off (so far so good). Also the bullet kit I got for my HD bulklet lights has side markers on them so there IS light from the side. People behind me (on scoots) have said they are very visible even on a bright sunny day.
Mike![](http://img.photobucket.com/albums/v319/mikefragala/Road%20King/01.jpg)
![](http://img.photobucket.com/albums/v319/mikefragala/Road%20King/003.jpg)
Mike
Guest
Posts: n/a
I had the old style (91699-99A) brake/directional module originally on my bike. Then the new style came out and I installed that one coz I thought it would be better with running/brake/directional. The difference in light intensity between running and brake was was barely noticable. I wanted additional brakelights that would jump out at you. These didn't. I went back to the old style. You can't get more noticable light than going from off to on IMO.
Panacia seems to be the best. Just a note on LEDs they are not always even as bright as standard bulbs, be carefull to get only those that say they are very bright. try here, lots of kool stuff.
http://www.customdynamics.com/
I picked up the Kury led light and found that the difference from running to brake was almost nothing. I did have the older HD brake/turn module and there was a compatabilty problem with it. I picked up the newer HD version that has running/brake/turn and I noticed two things. Firstly, rather then the regular 1157 bulb I had a 3357 bulb. There is a major difference between running and brake light output between the two.I put back the Kury led assembly and found with the new HD module, the led worked great and have received comments from my fellow riding buddies that the amount of light in the back is outstanding. I had put in the tour pack led which added to my visiblity. My next project is to try and figure out how to make the tour pack side marker lights into running, turn and brake lights also. Even if I can just get running and turn signals out of them, I would be very happy. In the NYC metro area, I find I am fine except for the cager in an suv talking on the phone or yelling at the kids with the dvd going.
