Old 03-16-2015, 05:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Interested in the Fuelpak FP3? The Fuelpak FP3 allows you to map your engine for optimum performance when using a Vance & Hines exhaust. The Fuelpak FP3 also allows you to see vital engine information displayed on your smartphone.
Read the full discussion below to find out what people are saying about their Fuelpak FP3.
Print Wikipost
NEW Fuelpak FP3
Old 05-04-2014, 08:18 PM
herkdavis's Avatar
herkdavis
herkdavis is offline
Not sure what's going on with my FP3 but when I flash the auto tune my bike runs bad and throws codes. I've tried several times different ways but I have same results. Will not idle and misses. Has rear cylinder lean code. If I reload base map it runs okay
  #132
Old 05-04-2014, 08:48 PM
Spazz's Avatar
Spazz
Spazz is offline
Are you waiting the necessary time to allow the VE tables to populate all green blocks prior to flashing?
  #133
Old 05-04-2014, 09:31 PM
Smittyjf's Avatar
Smittyjf
Smittyjf is offline
Exact same problem today trying auto tuning. This was my first time I've tried it.
I Had to reflash back to my selected map. no matter how many times I did it, it barely idled
  #134
Old 05-04-2014, 09:33 PM
Smittyjf's Avatar
Smittyjf
Smittyjf is offline
This is after selecting auto tune and initially flashing the map you want to tune with. The bike will not run right to even start the auto tune process.
  #135
Old 05-06-2014, 07:58 PM
Kazz's Avatar
Kazz
Kazz is offline
Yea I haven't heard of anyone totally completing a auto tune successfully yet. I myself ran several sessions but no cells where learned.
The bike would start ,then pop and spit , then smooth out. Ran fine for the whole session . But as I mentioned before. No cells where ever learned.
There's a iPhone update that is supposed too fix a bug with the app in auto tune. I updated it and will try auto tune again when I have time to do a solid run. Fingers crossed
  #136
Old 05-07-2014, 05:29 AM
Spazz's Avatar
Spazz
Spazz is offline
Just to get some clarification... is this autotune issue ONLY with the iPhone app and NOT the Android app.. or both....
  #137
Old 05-08-2014, 10:18 AM
tpmcd's Avatar
tpmcd
tpmcd is offline
I use the FP3 and an iPhone and have successfully done an Autotune twice on my 2012 FLD.
Flashing new maps and Autotune only seem to work reliably if I disable WiFi on my phone and force it to use Cellular Data. With both enabled things were pretty unreliable.
I'm not sure you will ever see a fully populated table. The matrix for the AFR table has RPM on one axis and % of throttle opening on the other. I think it would be hard to ride the bike and hit all of those condition combinations. It's been a couple of weeks but I believe my table showed a little more than a third of the table populated with green squares where it was able to completely measure and of course yellow around the edges where it did not have enough data in those segments for a complete tune.
I noticed that while Autotune was enabled my bike idled fairly rough the first time it was started each day. However, once I had ridden through the normal ranges I typically ride and "Finished" and flashed the Autotune results it starts and runs smoothly as you would expect. All in all I ran practically a full tank of fuel through the bike with Autotune gathering data.
  #138
Old 05-09-2014, 02:06 AM
hdoilcan's Avatar
hdoilcan
hdoilcan is offline
Does the FP3 stay on the bike after your done flashing ect? Does it get removed after your done? Was talking to the wrench at the stealers today and he said he thought that it doesn't stay on the bike..... He wasn't to familiar with it.
  #139
Old 05-09-2014, 02:49 AM
WildThang's Avatar
WildThang
WildThang is offline
You can either leave it in place or remove it....
  #140
Old 05-09-2014, 08:18 AM
tpmcd's Avatar
tpmcd
tpmcd is offline
You do not have to leave it on. However, even if you are not tuning the FP3 allows you to read engine temperature, RPM, etc. through your phone. If you are curious about what your engine is doing you might occasionally leave it connected so you can view that data.
Quick Reply: NEW Fuelpak FP3
