Gaterman 1023's
Gaterman 1023's
I'm almost ready to do cams, just waiting on a back ordered tool. I was intending on reusing my stock lifters, but I've got about 11K on my bike, and have no idea what my lifters look like. The Gaterman's seem to be highly recommended, but I have a couple of questions. Since I'm reusing my stock pushrods, are the 1023's a direct replacement? Where's a good place to source them? Any opinions are welcomed.
386-253-1899
Info@gatermanproducts.com
Call them or e-mail them, they will give you the information you are looking for.
Email Gary garybutler@optusnet.com.au and he will have you PayPal him payment and will get the lifters sent to you. I have a set coming as we speak. His prices are very good.
I am in a similar boat. The Gatorman 1023's are stock type replacement and work with OEM pushrods. I am in the middle of collecting parts still to swap in a set of Andrews 48H's. Purchased the lifters, cams, and a few other parts from Jim at Independent Cycles in Tulsa OK. Good fella to deal with and haven't had any problems.
My bike has some serious valvetrain noise which has 31k miles on it unlike the quiet valvetrain that it had at 14k miles. I am sticking with 1-pc pushrods as well, will probably replace the oem pushrods with Smith's but need to get into the rocker boxes to look for possible interference and anything that would cause extra noise.
Lifters are lifters as far as pushrod length. What determines if you can reuse stock length pushrods is the distance from the rocker arm to the base circle of the cam (shaved head = shorter pushrod, smaller cam base circle = longer pushrod, and of course there are combinations of cams/headwork).
I agree with the others that say cut the stock rods and use adjustables. Costs a little more (so that may be a factor), but saves quite a bit of time (and possible issues) with the partial disassembly of the top end.
