Visor Style Headlamp Trim Ring?
Anyone have this? When its installed it seems to have a gap at the bottom of about 1/4 inch and its bugging me. Not sure if there is supposed to be a gap or if I just cant get it tight enough. Any help would be appreciated. Thanks
http://www.harley-davidson.com/store...04-67700216--1
even in the H-D photo you can see a gap.
this is kind of a 3 hander...
make sure that the trim ring is seated behind the stock ring
try to get the trim ring in place and "close" with out causing any crimps.
I used a flexible rubber strap, like a strap wrench, to tension the ring and draw the opening closed
and the 3rd hand ( spouse) ran the electric screwdriver to hold it in that position
lots of complaints and comments on this piece...H-D could have done alot better that this.
mike
mike
