Visor Style Headlamp Trim Ring?
Old 02-04-2014, 06:32 AM
chopperguytampa's Avatar
chopperguytampa
chopperguytampa is offline
I removed the original ring so I could test fit the new ring off the bike. Even off the bike it leaves a gap. There is no way in hell it will close all the way because of the size of the stock ring. It's not possible. So I guess people just live with the gap or I got a factory defect. One of the 2.
Old 02-04-2014, 06:50 AM
foxtrapper's Avatar
foxtrapper
foxtrapper is offline
Veteran: National GuardVeteran: Navy
Received 1,665 Likes on 1,084 Posts
I've got both the frenched or eyebrowed type visor, and the full ringed type. They are not cut the same.
The frenched is cut shorter, and regardless of how tightly you pull it down, it will not completely eliminate the gap.
The full ringed type is cut a little longer, and carefully pulling it tightly down will eliminate the gap.
I cannot say if the two are always cut differently, or if it's just slop in the manufacturing process and that they all vary as a result.
Old 02-04-2014, 06:53 AM
NiteOwlNY's Avatar
NiteOwlNY
NiteOwlNY is offline
You know that really pretty girl with the gap in her front teeth that makes her just that much more sexier??? Yea, that! Hahahahaha....
I've noticed the gap and I've tried to ignore it, haven't tried to close it up yet.
Old 02-04-2014, 07:12 AM
UncleBigGeorge's Avatar
UncleBigGeorge
UncleBigGeorge is offline
I bought the visor from J&P. I haven't installed it yet (because I have other projects happening right now) but was wondering if anyone else had any issues with this part from J&P?
Old 02-04-2014, 07:52 AM
LeadSSled's Avatar
LeadSSled
LeadSSled is offline
I also was able to install these on my RK with no gap. as others mentioned, the key for me was to leave the factory trim ring underneath just a tad loose to let the frenched ring to get behind it. Having asecond set of hands during the install is a big help too.
These are the best pics that I've got.
Old 02-04-2014, 08:35 AM
chopperguytampa
I have a 2014 and the Visor is different then the previous years.
Old 02-04-2014, 08:39 AM
TheGrandPoohBah's Avatar
TheGrandPoohBah
TheGrandPoohBah is offline
Received 2,530 Likes on 1,425 Posts
Very small gap on mine.
Some are much worse.
Quality control issue with this piece what methinks...
Old 02-04-2014, 11:18 AM
canicta's Avatar
canicta
canicta is offline
This seems to be a common issue with these.If I remember I left the original off and installed the frenched one by itself.Don't know if I'm missing something by doing it that way but that's how I did it.With the"frenched " passing lamps,they came with some foam rubber for weather sealant or something.I couldn't get them to cooperate either so after looking it over I saw no reason for them so left the foam rubber out also.Short on patience mabe but haven't had an issue yet on either the headlight trim ting or the passing light trims rings.Did I miss something?
Old 02-04-2014, 11:25 AM
Sofakingkev's Avatar
Sofakingkev
Sofakingkev is offline
I used Irwin quick grip clamps.. Don't have a pic to post.
Old 02-04-2014, 11:32 AM
sixguns's Avatar
sixguns
sixguns is offline
Received 1,481 Likes on 761 Posts
If you put a little anti seize on the screw, it will really help you cinch it down and close that gap. Hope this helps.
Quick Reply: Visor Style Headlamp Trim Ring?
