J&M Headset in 06 ultra
Is anyone else having trouble with the J&M headsets. I have to yell to break vox, then it doesn't stay open very long. The wife and I cannot talk to each other. I've tried adjusting the vox and volume until I'm blue in the face. I called J&M and they tell me I have the correct lower cord. This set worked great in my Goldwing for years. I'm thinking there is a mixmatch here with the 06 ultra.
The music is great and my friends say my cb sounds good, however, I cannot hear myself when I talk on the cb.
Any help will be appreciated.
Don
Don
RE: J&M Headset in 06 ultra
If you are able to talk and be heard by others on the CBtheres probable nothing wrong with your headsets. I would guess there a problem with the radio system network for the intercom system [VOX]. Check it out with the dealer...bring both headsets and helmets with you and have them take a look see.
Yes, I tried adjusting everything I could and switched helmets with my wife. The J&M just didn't work well with intercom and CB. Since I had two HD headsets, I use these for two up travel and when I want to us CB with other riders. I installed the J&M without the microphone in a different helmet and use it when I just want music.
I'm having the same problem!! Driving me nuts! I've had the bike to the dealer twice, nothing wrong according to them. I send the headsets to J&M and the upper an lower cords -- nothing wrong!! ( I have the correct lower cord with 7 pins!). If i use only my headset, the CB transmits fine. If I add the passenger headset and try to transmitt on the CB, i get extreme noise!!! We also have the same problem with the intercom that you have.
I have read the owner's manual and the setting recommendations, but it's not working correctly. The intercom won't hold when we're talking and doesn't always start up like it should.
HELP!!!!!
HELP!!!!!
