I Have a 2010 FLHX and the Front Brake Handle / Master Cylinder is so tight to squeeze. The Calipers are ok as they do close & open but the pressure to squeeze the brake handle is way too much. Is that a bad master cylinder? It started getting tight a couple of days ago but it got real tight today. Any suggestions?
if you're brake lever is hard to pull, then take your bike back to the dealer. there was another one on here who had the same problem and it turned out to be the abs module....
Have you compared the squeeze feel with power off and power on? One guy claimed his lever felt normal with power off, but got extremely hard with power on. It sounded as if the ABS was blocking fluid flow, hence no front brake, when the power was turned on. Never heard the final resolution on that one.
ABS Module took a dump! Cant really understand why other than itr is a part & parts sometimes fail! HD wants to go the $400 part & $200 + install.... NOT!!!
Bought a mod out of a wrecked bike and will do the change out myself.
