2014 fairing switch blanks
Old 01-31-2014 | 12:34 AM
scarin's Avatar
scarin
Default 2014 fairing switch blanks
Guessing this is probably pretty easy, but how do you remove one of the six blanks in the fairing? Also does anyone have a source for switches (on/off and momentaries)?
Old 01-31-2014 | 06:59 AM
ejvette's Avatar
ejvette
Remove the ignition switch and 2 screws 1 on each side and the entire housing comes right off.
Old 01-31-2014 | 09:19 AM
hojones's Avatar
hojones
Take fairing cap off. Then unplug 2 wire plugs. Remove switch assembly 2 screws. Find metal rerelease on switchpak. Pull out 1/8 inch. Pry blank up with screw driver. Insert button assembly back into switchpak and push release tab back in. The switches are there all you need is the button. All the switches are momentary. You get the detent or the momentary function from the button assembly itself. as of now the only 2 buttons available are for lights (detent) and locks (momentary)
Old 01-31-2014 | 10:13 AM
wlibert's Avatar
wlibert
Do you know what the locks button does?
Old 01-31-2014 | 10:22 AM
hojones's Avatar
hojones
it is for the saddlebag locks on the CVO. It will work for anything you want . The only switch in the switchpak that goes to BCU is Driving lights.
Old 01-31-2014 | 10:31 AM
scarin's Avatar
scarin
Do you have part numbers on the buttons?
gnafin
EVO
09-08-2021 06:34 PM
mkguitar
12-20-2016 12:17 PM
Bo Joe
04-07-2013 04:39 PM
redhorse919
10-25-2009 02:27 PM
bldap
10-11-2009 09:50 AM
