S&S Power Tune duals or Cobra Power Port duals
Old 01-26-2014 | 07:07 PM
desertwolf's Avatar
desertwolf
Default S&S Power Tune duals or Cobra Power Port duals
Performance wise I doubt theres any noticeable performance difference between the two. So then it comes down to fit, finish, quality, durablity, customer service. How do these compare? Are Cobras made from 16ga? I've heard S&S has had some issue with mounts and bolts breaking? Do they both have a full size cross-over pipe? Which would you pick?
Old 01-26-2014 | 07:21 PM
artpe54's Avatar
artpe54
I have the S&S power tune duals. They changed the mounts. Great pipes I like mine.
Old 01-26-2014 | 07:37 PM
sg2007's Avatar
sg2007
I installed the Cobra Power Port duals on my bike this past week, the easiest install ever.They do come with full size crossover and they sure look and sound good with my Rienhart slipons.Dont know much about the S&S header, but they look similar.
Old 01-26-2014 | 07:59 PM
Bgill's Avatar
Bgill
I have the Cobra's and I am very happy with them just wish they had the dual 02 bungs....then they'd be about perfect!
Old 01-26-2014 | 10:46 PM
desertwolf's Avatar
desertwolf
Which 02 ports do the Cobras come with? Are the ports in the stock location? I know S&S comes with dual 02 sensors.
Old 01-26-2014 | 10:48 PM
desertwolf's Avatar
desertwolf
Fullsize crossover, that's a big plus. Are they made from 16ga ?
Old 01-27-2014 | 06:23 AM
Grillfish's Avatar
Grillfish
Kromewerks makes them for S&S. IF you do go with S&S, the KW ones are usualy lower priced.
http://www.khromewerks.com/
Old 01-27-2014 | 06:38 AM
sg2007's Avatar
sg2007
Dont know if there made of 16 gauge steel, dont know if that makes a difference or not.They look well made, I just put them on and rode off.I dont think Cobra would make a flimsy header would they?......
Old 01-27-2014 | 07:20 AM
Deckman's Avatar
Deckman
Depends on the year of your bike with the S&S Power Tune duals. I have them on my 07 street glide and I scrap the right side on the clamp right where the main pipe attaches to the cross under the Trans cover. Fit was good with no problems. Performance, compared to my True Duals, not much difference, but a lot less heat on the back of my left leg.
Old 01-27-2014 | 08:02 AM
sg2007's Avatar
sg2007
No problem with the Cobras, rode this weekend and lean hard left and right.....Desertwolf,my headers came with the 12mm sensor ports.
Quick Reply: S&S Power Tune duals or Cobra Power Port duals
