Bagger Apes Please help me decide!!!!!!!!!
Old 01-25-2014 | 11:21 PM
Sethcat's Avatar
Sethcat
Here is a picture of la choppers twin peaks 12 in. I have them as straight up and down as I can in this picture. A little higher than I anticipated but perfect now that they're on. I'm 5'8" and my arms are just slightly above parallel when I'm slouching, about parallel when sitting straight up.
Attached Thumbnails Bagger Apes Please help me decide!!!!!!!!!-wp_20140110_23_33_48_pro.jpg
  #32
Old 01-26-2014 | 05:30 AM
kojak's Avatar
kojak
Of all the ape hangers I've put on my road kings, Carlini's Flying Apes have been the best in finish, fit and durability.Their apes for street glides are called Gangster Apes. Check them out.
  #33
Old 01-26-2014 | 05:41 AM
Jswerve's Avatar
Jswerve
If you're doing anything less then 12's you're gonna block the mirrors. I am 5'6" short and I went with Cyclesmith 13's. They are mocked up just started the install. Makes my arms even with my shoulders and doesn't cover my mirrors.
  #34
Old 01-26-2014 | 07:10 AM
jjpish's Avatar
jjpish
I am 6' with long arms. I went with the LA Choppers Prime Apes that are 13's. I have had these for two riding seasons and they are perfect.
  #35
Old 01-26-2014 | 07:49 AM
Briguy1's Avatar
Briguy1
Do you have to change the cables or wires with the LA Coppers 10 inch twin peak apes?
  #36
Old 01-26-2014 | 08:01 AM
HDV-GLIDE's Avatar
HDV-GLIDE
Unless you reroute your clutch cable, you will have to get a longer one. Reroute it and your good with all the stock lines and wiring. I personally would get a +4 clutch cable though.
  #37
Old 01-26-2014 | 09:12 AM
SBates08's Avatar
SBates08
I haven't had to change or reroute clutch cable at all on the 10" Twin Peaks but I will admit its at its limits.
  #38
Old 01-26-2014 | 09:33 AM
Sethcat's Avatar
Sethcat
For the twin peak 12's, I got a +4 clutch and kept the routing same as stock. I was able to use the stock brake lines though. I have my bars as straight up and down as possible though.
  #39
Old 01-26-2014 | 10:16 AM
Proaction14's Avatar
Proaction14
Very cool J, that's gonna look great. I'm sure we'll see the results soon.
  #40
Old 01-26-2014 | 10:26 AM
bigskyroadglide's Avatar
bigskyroadglide
before you decide, check out these. Great fit and finish and 1 1/2 inch. makes internal wiring a breeze
http://www.bukybars.com/
AlphaDogg
09-21-2021 11:59 PM
sloans4x4
08-11-2017 01:11 PM
05hdultra
05-15-2015 06:43 PM
Bullbutch
07-03-2014 08:22 PM
Jack48S
06-23-2013 05:35 PM
Quick Reply: Bagger Apes Please help me decide!!!!!!!!!
