vance & hines fulepak
Old 03-19-2007 | 12:19 AM
jrtiller57's Avatar
jrtiller57
Default vance & hines fulepak
05 roadking with wildpig slipons
has anyone ran a v&h fuelpak? what do you think of produce?
Old 03-19-2007 | 12:28 AM
curmudgeon's Avatar
curmudgeon
Default RE: vance & hines fulepak
ORIGINAL: jrtiller57
Always eat your vegetables
Old 03-19-2007 | 12:38 AM
SoCal_Pappy's Avatar
SoCal_Pappy
'07 Road Glide - Samson 29" turn-outs - Ness Big Sucker Air Kit - Vance & Hines Fuel Pak
Works for me !!! [8D]
Old 03-19-2007 | 12:40 AM
berettag's Avatar
berettag
I like Produce. Good for you.
Old 03-19-2007 | 12:50 AM
xxxflhrci's Avatar
xxxflhrci
There are better tuners out there than a Fuel Pak. It is one of the newer ones on the market. There are ones with longer track records. Customer service for the Fuel Pak is said to be poor. There are other tuners that are more user friendly, IMO.
Old 03-19-2007 | 01:21 AM
SoCal_Pappy
Never had a problem with V&H customer service... And I have contacted them many times... They have Always helped right away with the answers even with products (mufflers\exhaust systems) that are not there's...
Old 03-19-2007 | 01:37 AM
brokenfingers's Avatar
brokenfingers
I use it and don't have any problems with it, in fact I really like it. I've called their customer support and had no problems, its simple and easy to use, and won't void your warranty because you can simply unplug it and nobody knows the difference. I think if all you are going to be doing is duals, slip-ons, and a high flow air cleaner... it works perfect. If you are going to be taking it a step further and going with performance cams and further stage kits... then you'll probably need something you can tune on a dyno.
Old 03-19-2007 | 10:46 AM
DeeRoe's Avatar
DeeRoe
Veteran: Air ForceVeteran: Marine Corp
I kept the stock airbox on my 07 FLHTC, K&N filter, V&H basic slipons and the FuelPack. Called Customer service and asked if they could recommend a "Richer" fuel setting. Within 4 hours, they called me back, spoke with the techrep about what I wanted. They gave me a setting to use OTHER than the one that was with the Fuelpack instructions, and the bike runs just the way I like it. Checked the plugs after a highway run, and they are just a tinge under white......not even a light tan, but darker than the total white on the ceramic. I AM VERY PLEASED!!!
Old 03-19-2007 | 11:56 AM
Pastor John's Avatar
Pastor John
I have the FuelPak on my '07 Road King matched with the SE Street Performance Touring Mufflers and the SE Stage 1 Intake. With this combo, my plugs are showing good color, and I think the air/fuel mixture is much less lean than stock. I also get good power delivery. But I have a troublesome flat spot at about 3000 rpm that is driving me nuts. V&H customer support has been largely non-responsive, and it looks like I'm going to have to live with it or go to a different fuel manager.
On the other hand, when I had the V&H Oval Slip-Ons installed with this same intake and the FuelPak, it was a marriage made in heaven! The power delivery was awesome and linear and I was very pleased (except for the loudness of the mufflers). I suspect that V&H goes to great lengths to dial in the FuelPak maps for their own exhaust systems, but spends less time with third-party applications.
Old 03-19-2007 | 12:57 PM
gunrunner's Avatar
gunrunner
Fuel pack did as good performance wise on my 07 as the pcIII does, PCIII causes a delayed start on 06/07s fuel pack does not. If your mods are just air cleaner and slipons it will do great, if you plan on more then the pcIII or sert would do better.
torpidrabbit
Dyna Parts
02-28-2016 03:11 AM
snotracks
08-11-2012 01:05 PM
tbone22
03-06-2007 05:03 PM
06Softail
04-05-2006 04:10 PM
engot
01-31-2006 09:13 AM
Quick Reply: vance & hines fulepak
