kst 12" mayhem install help
decided to go with the kst 12" mayhem for my 07' streetglide did a search not much help can anyone point me to a thread that has all parts to do the job i can swap out the bars and do the extensions but the clutch and brake lines may take to shop thanks for any help.
Received 1,313 Likes
I don't know there is a thread for it but you will need extended cables for your bar controls, if you have a throttle cable they need changed +6" and the clutch cable. Parts are easy to find on JP Cycles or Dennis Kirk websites. You can google the bars and find other peoples parts list and videos of how they did them. Harley dealers sell the extended wiring harnesses with the buttons on them, fish them thru the bars and cut to the length you need, install the old plug ends, pretty simple.
Rome I am running 14" Mayhems and went with +8 clutch and it almost wasn't enough. I would suggest +8 clutch cable and +6 brake line and throttle cable and you should be able to run everything back in its stock location. Would also recommend +8 on your hand control harnesses to get them back to their stock mounted positions inside the fairing. You can either buy the extensions or extend it yourself. If there's anything else you need just give me a shout.
Oh...doing the clutch and brake yourself really isn't that hard.
Buckinfitch
12-29-2011 08:39 PM
bikerjenna
03-20-2011 04:45 AM
