american custom slip on bomber mufflers
Old 01-20-2014, 01:51 PM
tagalongtrouble's Avatar
tagalongtrouble
tagalongtrouble is offline
Default american custom slip on bomber mufflers
http://www.americancustom.com/checkout/cart/
Anyone have any feedback on these? Just the mufflers? Under FAQ they claim no remapping required. Sure my new 14 SGS 103" mill is gonna be plenty powerful for me, just mught be looking for a bit more sound/road presence and love to minimize need for dealer service to re-calibrate-dyno etc. Anyone??
Old 01-20-2014, 02:08 PM
jeffreydsilver's Avatar
jeffreydsilver
jeffreydsilver is offline
I put the bombers (with the mid range baffles) on my 09 Road King (stock air filter) but I got a slight decel pop with engine braking, so I put on a V&H Fuelpak. Problem solved! I have since drilled out extra holes in the baffles for a slightly louder / lower sound. I don't know anything in regard to the 2014's, but I will add that if you are going to do ANYTHING beyond air filter and exhaust, the Fuelpak would be a waste. You would want something more tuneable and more easily adjusted.
Old 01-20-2014, 02:34 PM
hardheaded's Avatar
hardheaded
hardheaded is offline
Received 2,633 Likes on 1,628 Posts
i have a set on mine with no baffles in them, running fl-vied-10 set at %50 and it runs good with no popping in exhaust. anything more than pipes and air cleaner you need a tuner. i like my setup and it was cheap. 12 streetglide
Old 01-20-2014, 03:10 PM
biker_ded's Avatar
biker_ded
biker_ded is offline
I'm running them on my '14 Ultra-no baffles. No popping, runs absolutely wonderful as is. Nice deep rumble and can still easily hear radio. If anything, they could be a little louder without the baffles to suit me.
Old 01-20-2014, 03:23 PM
RebelBugler's Avatar
RebelBugler
RebelBugler is offline
I've got the American Custom Bombers and Powerflex headers on my 2012 RK and love the sound and performance boost. No additional tuning should be required unless you upgrade your air cleaner.
American Iron Magazine did a review on the American Custom complete exhaust upgrade and provided dyno results for the system with the various baffles.
If anyone is going to Daytona, American Custom generally has their crew there and will install systems on site at great prices. I had my system installed there last year and couldn't be more pleased.
Old 01-20-2014, 03:56 PM
tagalongtrouble
So if im goin for the slip on bombers only it should be plug and pay??
Old 01-20-2014, 04:57 PM
freedub2003's Avatar
freedub2003
freedub2003 is offline
They are HD mufflers that have had the stock baffles/core drilled out and replaced with the American Custom baffles. They are a direct replacement. I have the Bomber series with mid baffles and I too drilled some extra holes (8 i think) in each baffle. the baffles take just a few seconds to remove.
Old 01-20-2014, 06:12 PM
artpe54's Avatar
artpe54
artpe54 is offline
I have the Bombers with S & S power tune headers. Had it tuned with a TTS.
Old 01-20-2014, 06:40 PM
SPECIAL ED's Avatar
SPECIAL ED
SPECIAL ED is offline
I like mine but to me they're ridiculously loud and run like hell with the baffles removed.But I do have a Ness AC, with the mid baffles in and some extra holes drilled in them it sounds good to me.That said I never tried them with the stock AC or with a cat in the header probably work just fine.Even if it doesn't you an always add the baffles later.
Old 01-20-2014, 07:10 PM
kpb46's Avatar
kpb46
kpb46 is offline
I have a set on my SGS. no other mods. Sounds great and runs great. Some minor decell popping occasionally. Nothing that bothers me. Call them they are great to deal with. I have the loudest baffle option.
Quick Reply: american custom slip on bomber mufflers
