Any detachable tourpacs on 2014 Limiteds?
Old 01-19-2014 | 08:36 PM
Wally's Avatar
Wally
Default Any detachable tourpacs on 2014 Limiteds?
Was checking out a 2014 Limited on Saturday at the dealership. The salesman couldn't tell me if the tourpac could be made detachable. Anyone done it?
Old 01-19-2014 | 08:39 PM
CJ Sedona's Avatar
CJ Sedona
No .
Well technically yes but it's a fairly complex conversion
Would have to cut/splice in electrical connectors for lights and change the permanent mount all over to a quick disconnect system
Old 01-19-2014 | 08:43 PM
SafetyMan's Avatar
SafetyMan
It can be done, one of the guys here did it.
He used Plasma Rods, and it turned out SHARP!
I'd be willing to wager the moco will come out with a kit soon....
Old 01-19-2014 | 11:05 PM
Clint55's Avatar
Clint55
Would have been an easier mod if the MOCO hadn't decided to remove the rear turn signal bar on 14's..
Old 01-20-2014 | 04:15 AM
grbrown's Avatar
grbrown
Red face
Indeed! It does seem a strange move, especially after they went to so much trouble a few years ago to introduce detachable TP mounts.
Old 01-20-2014 | 06:09 AM
rwrunski's Avatar
rwrunski
It can be done with some work. An option would be to switch out the rear fender with one from a road king(matching color) then you would have the tail light turn signal set up. There is no wire harness yet but this can be made.
Old 01-20-2014 | 06:48 AM
BARACU's Avatar
BARACU
Big Kahuna HDF Member
I did it on my '14 Ultra. Remove saddlebags and remove four bolts that hold the TP base on. Wires and antennae are quick disconnect and coil nicely under the seat. I fitted a set of RoadKing turn signals to the rear fender. It requires drilling two holes. The brake light has a separate wire harness so, the turn signals plug right into the brake light assembly .
Attached Thumbnails Any detachable tourpacs on 2014 Limiteds?-img_0174.jpg   Any detachable tourpacs on 2014 Limiteds?-img_0172.jpg
Old 01-20-2014 | 06:59 AM
brettnbama's Avatar
brettnbama
There is a dealer meeting this week for P&A. I am betting we may see some lights designed for the slots in the strips between the fender and bags
Old 01-20-2014 | 07:39 AM
Wally's Avatar
Wally
You're saying the plugs are there and ready to go?
Old 01-20-2014 | 07:47 AM
BARACU's Avatar
BARACU
For the turn signals. If you take the brake light lens off, just to the left of the chrome bolt there are two 3/8" x 3/8" female receptacles that the turn signals plug into.
Quick Reply: Any detachable tourpacs on 2014 Limiteds?
