Removed caliper body bolt instead of pin bolt
Ok, apparently I'm the only guy who's ever done this, searched and couldn't find any info on this prob.
So I had to replace fork seals, figured replace front pads while everythings apart, getting on the thin side. Started with L. side, and somehow removed caliper body mounting bolts instead of pin bolts, seen fluid leaking out of caliper body, realized after both bolts completely loosened.
Quickly tightened em back up, cussed, trying to figure if I did any major damage. Obviously need to bleed now, but fluid was already in terrible shape, master cylinder full of sediment.
Will having loosened bolts messed up pistons? nothing fell out, just the fluid. Hoping I just need to bleed em, but don't want to half *** the front brakes.
So, what was the outcome? Just tighten em back up, bleed the brakes and everything was OK? No problem with seals, gaskets etc?
Just curious in case I make the same mistake.
