Cell Phone Handlebar mount
mhcruiser I had found the motomount and liked it.
Do you have any pictures of your setup? Did you mount yours down near the base of the bars?
One of the things I did not like about the ram mount is how it attaches to the bars the motomount is definitely cleaner and takes up less space
I know you already got something, but I'm going to go with the Cell Buckle. I was in the same spot then I remembered about the Cell Buckle, it's $15 and you take it off when not in use. So I don't have worry about what it looks like, and I can mount it where I want for the day. It's pretty cool, J&P also has a video about it. Here's the link if you still want to check it out.
http://www.jpcycles.com/product/692-443
Michaels Stainless Innovations
There are no smaller mounts and it can be mounted on either side.
http://www.michaelsstainlessinnovations.com/abouts.html
This mount works very well. Sturdy mount that bolts to your handlebar. This can be moved to any position for easy visibility. Uses OEM Ram components. You can also use your smartphone as a GPS if you need to.
![](https://scontent-a-iad.xx.fbcdn.net/hphotos-prn1/1148924_652657941413524_1562371823_n.jpg)
This can be purchased at GPS Bike Mount - http://www.gpsbikemount.com/ramhandlebarmountkit.html
Received 1,573 Likes
