spark plugs?
i stick with the stock hd plugs for one reason. the ecm requires your spark plugs to be a certain ohm rating in order for the knock sensor to work properly. other plugs may fit, and they may or may not have the correct resistance. i know the stock hd plugs do. it isn't like you have to change them with every oil change anyway so to spend a couple extra bucks on the hd badge is no big deal.....
i use the v-rod plugs in my 12 CVO. They are a colder plug and it reduces the tendency of the 110 to ping under load. Replace every 20K.
in my 04 which is a 107, i run autolite plugs from the local auto parts store. they are about a $1.50 and i replace them every 10K.
The 04 tends to be more tolerant of non HD plugs than the 110.
