Reflex brakes street glide
No the reflex brakes are a fancy name for the braking system. They are now linking the front and rear brakes when under 20mph. If you hit the back brake pedal it will automatically apply one of the disks up front. If you hit the front brakes it will also apply the rear brake. ABS is just like in your car.
The metric bikes have used this brake system for a while with great results.
lonur1
ABS will not allow the wheels to lock up and skid, it will pulse the calipers when it is activated to bring you to a safe stop.
no reflex w/o abs, abs controls it. Mike
Reflex™ Linked Brakes with ABS: All 2014 Harley-Davidson Touring models are available with the new Reflex Linked Brakes with ABS as either Original Equipment or as a factory-installed option. Reflex Linked Brakes combine ABS with electronically linked brakes that dynamically optimize front/rear brake balance. Linked braking is activated when the motorcycle is above 20 to 25 mph. If braking is initiated at slower speeds the front and rear brakes function independently. When linked braking is active, applying the front, rear or both brake controls will apply braking force to both the front and rear brakes in a proportion determined by the Reflex Linked Brakes system to optimize performance. The braking will stay linked as speed drops below the 20-25 mph threshold. Reflex Linked Brakes incorporates ABS to further help the rider maintain control during braking events, especially those that happen in less-than-optimal conditions. Reflex Linked Brakes with ABS are Original Equipment on the 2014 Street Glide Special, Electra Glide Ultra Classic and Ultra Limited Harley-
