Can the cat be gutted/drilled out while on the Bike?
Just received my Jackpot S/O mufflers, and about to put them on, but wanting to gut the cat. I've read lots about ways to do it such as using a long paddle bit, but haven't seen anything about doing while on the bike. Can it be done or do I need to take the pipes off?
I drilled mine out off the bike. Technically it probably can be, but it would be difficult in my opinion. To add to the previous poster...the stuff breaks off in chunks as you drill it out and would be tough to make sure you get it out without being able to turn the pipes upside down and twist around and stuff.
Good advice! I cut a panel in mine to get the honeycomb stuff out on a Saturday afternoon. Then I had to find someone to weld the darn thing back together. After everything was said and done I ended up buying a set of S&S headers to replace it because of a leak in the welds, ARGH!
Received 2,529 Likes
