Antenna Issues
Old 09-02-2005 | 02:07 PM
jlacasci's Avatar
jlacasci
Default RE: Antenna Issues
It's unreal how badly I type things on this forum. In my last post I meant that I haven't used the CB yet not CD!!!! I hope that was somewhat obvious. My fat fingers need to go on a diet.
Joe
Old 09-03-2005 | 10:37 PM
luvmyflhtcui's Avatar
luvmyflhtcui
I cut each antenna down 8 inches and then adjusted the CB load for the shorter length and I am good to go. The antenna's clear with room to spare. There are proceedures in the service manual to adjust the CB Load.
I didn't spend a dime and I solved the problem in my garage.
Good Luck.
[IMG]local://upfiles/494/0D738EA1F9EE497FB096430E2913B73A.jpg[/IMG]
Old 09-04-2005 | 03:46 AM
mikeisglidn's Avatar
mikeisglidn
ill check on the other type of dykes im sure there are some around he somewhere, ill get a couple that are mechaniclly inclined!!
Old 09-04-2005 | 11:36 AM
Big daddy's Avatar
Big daddy
Stage I
I have the wipes as well. They are quite the problem. I Just remove mine. But , I have to remember to put it back on. I would also like to get the shorties. Ya'll have alot fo good ideas.
Old 09-04-2005 | 02:39 PM
steveokla's Avatar
steveokla
I ordered a set of the Freedom Cycle antennas. Do the old ones just unscrew and you screw in the Freedom Cycle ones???
Old 09-04-2005 | 03:41 PM
jlacasci's Avatar
jlacasci
Pretty much that's it. Lift up the rubber, undo the allen screw and unscrew the.
Litle locktite (blue) on the screw mount, and screw the new ones on.
Joe
Old 09-05-2005 | 03:42 AM
nmfxstc's Avatar
nmfxstc
Let us know what effect the CB antenna has...I get great range and reception with the stock whip, but if these Freedom Cycles ones work....I'm gettin' 'em!
Old 09-05-2005 | 02:44 PM
Toytech's Avatar
Toytech
The Freedom Cycle antenna have equal range as compared to the whips. One added plus is you can cover your bike with little hassle and limited risk of snapping them off. I just thought I would throw that in. No one had brought that up yet.
Joe
SugsPa
03-14-2012 09:15 PM
IBHarley
08-29-2009 08:19 PM
BLUEICE
10-02-2007 11:10 PM
jlacasci
10-01-2007 12:15 PM
alfalf
02-27-2006 11:06 PM
Quick Reply: Antenna Issues
