High flow AC installation
I finished it. Pulled the tank all the way off. I've done it a few times on my old bike (08 SG) so it wasn't a big deal. Just a few butterflies on a new one...
The two bolts in question were really in tight. I don't think I would have got them out without lifting the tank.
You guys that have done it on a 14. There was a plastic clip on the induction module bracket (Part "B" in the diagram I attached above) that held two connectors. Can't have the clip without the induction module bracket. I assume you leave the clip out?
This is what I did. It was a bit tight, but just took a little more time & patience. I really wanted to avoid taking the tank all the way off. It worked.
unless for purely cosmetic reasons, no need to change the A/C on 14s to "high flow". that A/C assembly will flow more air than any stage 1 or stage 2 will require with a simple change of the paper element to a K&N element. my .02
Not all aftermarket air cleaners require the removal of this bracket. My suggestion is to pull the stock back plate off, fit the new back into place to see if it's required.
UN you are probably right, but since I am trying to do my Stage 1 this winter and there isnt a K&N replacement yet, I went with the SE with a K&N. I might should have waited, but I have never been known for my patience.. I did keep everything that I took off incase i want to change back later.
gilbert_roadking
06-04-2015 01:03 PM
MoparFreak
Exhaust System Topics
03-19-2012 11:30 AM
