To go gear driven or stock on cams
what engine do you have ??? on my TC88 I went with S&S 510 Gear Drive kit at 30k...glad I did , my tensioners were in pieces and I will never have to worry about them again! Peace of mind well worth it. Picked up the kit on e-bay a few years back for a great price ( sorry cant remember details)
gear driven are thought to be more accurate for cam timing ( valve opening and closing). so that's the plus.
If your model has known weakness with the cam drive system...a real, real plus
Negatives; generally will cost more, install may be more fiddly, and may be noisier.
If I were to do cams, even on an 09, it'd be gear driven
mike
mike
Very true, I believe I've read in several places where the max runout is .006, and many, maybe most, engines are well over that. Everything being equal, I much prefer gear drive, so as to never be concerned about shoe wear again. That said, your '09 has the updated system, but at some point in time, those plastic followers will wear out, and going to gear drive takes care of that.
The issue of more accurate timing is a minor thing, and most of us will never be affected by this advantage. It's very possible that the engine will be more noisy, and for many of us, that's a moot point, we rode Harleys when they were MUCH more noisy than today's Twinkie engines. For me, given the ability and budget, oh yeah, no question, I'd go to gear drive, hands down.
Don't forget to replace your lifters, as well...some don't, I'm of the old school persuasion that decrees that you replace lifters when you replace the cam, plus on many Harley engines, lifters don't last that long. Don't scrimp on lifters...they are under a hell of a lotta stress, they are a known trouble point, and when one goes out, you go to the side of the road, and maybe a total engine rebuild if you're unlucky when all those little bearings get strewn thru your oil system!!!
I also highly recommend going to adjustable pushrods, there are advantages with staying with one piece rods, for my money, adjustables are simply a necessary part of the equation...
And do go back and research the many threads on this forum alone on this issue...TONS of information on it.
