To go gear driven or stock on cams
Old 01-04-2014, 04:48 PM
12hdrk's Avatar
12hdrk
12hdrk is offline
Originally Posted by grbrown
Harleys have used gear cams since the dawn of time and still do on the Sportsters. However the chain-drive seems to have had its teething troubles ironed out now and if I still had my twincam I would simply upgrade that, rather than bother with checking crank runout.
Yea. I agree. I didn't check the runout when I did my tw-555's. I never thought to do gear drive. The tensioners on my 12 103 look well designed. Don't see the point in switching to gears. Doing the 107" kit and heads now and I'm tempted to check but in reality I'm not gonna rip it all apart even if it is out of spec. I'm gonna ride it...
Sent from my Galaxy Nexus
Old 01-04-2014, 04:57 PM
QC's Avatar
QC
QC is offline
Received 19,803 Likes on 9,866 Posts
It is highly unlikely your crank run-out will meet .0035 or less required to go gears. Replace the original shoes with Zippers/Red Shift tensioners.
http://www.google.com/url?sa=t&rct=j...58187178,d.aWc
Old 01-04-2014, 05:00 PM
hambone51's Avatar
hambone51
hambone51 is offline
My tensioners were toast at 20k miles. Went to gear drive and so far so good. Quiet after about 5k miles. Crank run out is key. If too much ,excessive wear and noise are on tap.
Old 01-04-2014, 06:05 PM
OldPhat's Avatar
OldPhat
OldPhat is offline
+1 what grbrown said
Old 01-04-2014, 06:07 PM
djl's Avatar
djl
djl is offline
Received 2,227 Likes on 1,611 Posts
.003" is max runout recommended to run gear driven cams.
The thing I don't like about the later OEM cam plate is that the outer cam journals run in the parent material of the cam plate. I have seen a few that showed excessive wear after performance cams were installed; not many but enough that I would not run performance cams in the later OEM cam plate in one of my bikes but that's just a personal thing; plenty are running performance cams in the later OEM plate apparently with no issues.
If the OP decides to upgrade the cam chest he could do it with the 25282-11 kit with billet plate and higher capacity oil pump or gear drive, if the selected cams are available in gear drive. Gear drive setup would cost a bit more, so, assuming runout is within limits, it's a personal choice. Certainly more work to setup; the 25282-11 kit is caveman simple to install.
No worries on lifters. With roller lifters it is not necessary to install new lifters with new cams; again, a personal choice. If the lifters have 35K mile or so on them, replacing them would be a smart thing to do. No need to break the bank on lifters, CompCams VThunder lifters and the new CYCO lifters are less than $60 a set to your door. JMHO.
Old 01-04-2014, 06:10 PM
qtrracer's Avatar
qtrracer
qtrracer is offline
Originally Posted by JKSHYT
Looking to go for a new cam. Either SE cam or woods 555 or 777, here is the question, conventional dr or gear driven.
Does anyone have any experience on one or the other?
Thanks in advance.
As far as I know you can't go gear driven in SE cams. That makes that choice a bit easier.
Old 01-04-2014, 06:12 PM
QC's Avatar
QC
QC is offline
Originally Posted by djl
.030" is max runout recommended to run gear driven cams.
Typo?
Old 01-04-2014, 06:24 PM
revelator2's Avatar
revelator2
revelator2 is offline
I did the screamin' eagle update with the hydraulic tensioners and used S&W cams on my TC88. I have 30k plus miles on them with no regrets and zero problems. I'd probably do it again if I had to.
Old 01-04-2014, 06:54 PM
Stiggy's Avatar
Stiggy
Stiggy is offline
Received 5,821 Likes on 3,173 Posts
Originally Posted by QC
Typo?
(EDIT : I meant three thousandths below ,not thirty!)
.0030" ( thirty thousandths,) is the original acceptable run out on the 99 -02 twin cams with the hot forged crank supported by the Timken Left taperes bearings per Harley Davidson. Somehow (?) Harley now says that the weaker, later cranks have a new tolerance of .012" ( 4 times as great.)
But I do have the good motor, so I have gear drive cams installed Jan '11 at 81,000 miles and still going strong 3 years later at 140,000 plus, and still running the original cam plate and oil pump.
I wouldn't have it any other way with my bike but later models would do well to stay with the hydraulic tensioners IMO when doing a cam upgrade.
Old 01-04-2014, 07:06 PM
rick2800's Avatar
rick2800
rick2800 is offline
I have checked 1 2007 flhx 1 08 ultra and 1 09 flhx all the cranks between .040 and .045 run out so we all just put the chains and tensioners back on. another friend has an 05 police bike it also had .040 run out he put chain drives in and they are noisey kinda a whiney sound.
Quick Reply: To go gear driven or stock on cams
