Timing cover adjustment?
Old 01-02-2014, 10:07 AM
cmstewart72's Avatar
cmstewart72
cmstewart72 is offline
Default Timing cover adjustment?
Does anyone know if the timing cover itself can be adjusted? I have an 11' RKC and want to put the "103" cover on it, but noticed the cover on it now isn't exactly flush to the ground. It needs to be rotated about 1/2" to 3/4" counter clockwise to be straight. I am assuming the cover screws directly into the casing and there is no room for such an adjustment. Any ideas out there in HarleyLand? Thanks!
Old 01-02-2014, 10:42 AM
highmarket's Avatar
highmarket
highmarket is offline
Do you mean the cam chest cover right side or clutch cover left side ?
Old 01-02-2014, 10:51 AM
Black_Hog's Avatar
Black_Hog
Black_Hog is offline
If you post a photo it might help us understand what the problem is.
Tee Bagger's Avatar
Tee Bagger
Tee Bagger is offline
Do you have a pic? The insert is not adjustable... there is nothing behind it... you can remove it and see.
Old 01-02-2014, 11:22 AM
cmstewart72
Default Clarify...
Sorry about the confusion. The timer cover that would be on the right side by the right side running board and directly under the tappets. Attached is a picture and hopefully you can see the misalignment.
Old 01-02-2014, 11:25 AM
cmstewart72
And...thank you all for looking at it. I suspect there is no remedy for this. I will probably get the Harley Davidson Motor Co cover (HD part 25338-99) and matching timer cover instead. The misalignment wouldn't be as obvious. HOW this isn't straight, I'll never know, but I will adapt and overcome.
Old 01-02-2014, 11:33 AM
0ldhippie's Avatar
0ldhippie
0ldhippie is offline
It looks lined up with the engine. That is the way they are...
Old 01-02-2014, 11:34 AM
Rock Chalk's Avatar
Rock Chalk
Rock Chalk is offline
that looks pretty straight to me....are you wanting it to be square to the footboards?
Old 01-02-2014, 11:36 AM
cmstewart72
Cool Better Pic...
Attached is a better shot of that whole side. Is there a trick to making the pictures appear in the message instead of making you click on them? When I try and click on these links to open a picture, it tells me I am unable to do so.
Old 01-02-2014, 11:41 AM
cmstewart72
Granted...I possess a level of anality that is almost unparralled in human history, but to me, that cover/emblem should be level with the ground. Perhaps the motor has a slight tilt to it that I am not seeing. My idea of it being "level" may be trumped by intentional design by HD. Now that I look at the rocker boxes...there does seem to be a "lean" forward.
Quick Reply: Timing cover adjustment?
