premium luggage rack
Old 03-17-2007 | 12:19 AM
gver1031's Avatar
gver1031
Default premium luggage rack
just purchased a new luggage rack for my ulta any tips for a smooth install and what works best to seal the drill holes?
Old 03-17-2007 | 01:49 AM
wldbill's Avatar
wldbill
Default RE: premium luggage rack
Follow the directions, and measure 3 or 4 times and drill once. Mine has been ridden through some horrendous rain and hasn't leaked yet. Used only what came with the kit.
Old 03-17-2007 | 07:32 AM
pino56's Avatar
pino56
start with very small bit for pilot hole. I taped my spots prior to drilling to avoid any chance of bitslipping. I used a marine grade silicone I happened to have.
Old 03-17-2007 | 09:45 AM
christian0632's Avatar
christian0632
I paid the 25 bucks and had the shop do it.
Old 03-17-2007 | 11:50 AM
snoopy's Avatar
snoopy
The 25bucks is usally the cheapest way for me to.
Old 03-17-2007 | 12:15 PM
ndotken's Avatar
ndotken
I put masking tape down where the four holes were going to be drilled and then marked one hole and drilled it. Then I placed the rack on the bike with that one bolt and checked the marking for the next hole ... repeating this process and only drilling one hole at a time.
I know it took alot longer for me to do it this way, but you only get one chance to do it right. And it turned our perfect.
Old 03-17-2007 | 01:34 PM
berettag's Avatar
berettag
All the steps outlined above are good advice. Measure many times, drill a small pilot hole first, attach one screw after drilling a hole and triple check the other marked holes to be drilled. I used black RTV to seal. No fuss, no muss. Good luck.
Old 03-18-2007 | 10:04 PM
gver1031's Avatar
gver1031
thanks for the replys should have it on shortly
Old 06-05-2007 | 06:05 PM
bloozeman2002's Avatar
bloozeman2002
I'm about to pick one of these up.. Is there a template for drilling, or do you have to place and mark it?
Old 06-05-2007 | 06:17 PM
Pacemaker's Avatar
Pacemaker
ORIGINAL: bloozeman2002
My came with a template. But when you drill you have to follow the same angle as the post/leg.
Quick Reply: premium luggage rack
