06 roadking ecm
06 roadking ecm
Hi, i have a 2006 roadking, had bike at the dealer recently, and had them reflash the ecm back to stock, since that was done, my check engine light comes on, checked codes p0134-0154, no oxygen sensor signal front and rear. Bike is a 2006 and dont have sensors, did i get the wrong flash, and is there any way i can tell what vin they programmed into the ecm. thanks
Here is the scenario. I did a 95 build and my local tuner wanted the ecm flashed with the stage 1 and then he would tune from there. My build got done, and when it came time to get the stage 1 flash, no dealer could produce. They said that in 2006 harley was conceding to the epa and would not offer a stage 1 flash. A year later, the same story. I don't know if that changed for the 2007, but I assume it did. The dealers claimed that they had nothing besides the stock program to flash into a 2006 ecm.
How did they program it to start with? Trust me, just because the ecm was programmed, doesn't mean that the dealer will have the ability to change it. I've been a gm tech all my life, and this is fact in our world...
harley told me they download the stock flash from harley and load it into your ecm with the digital tech scanner, thats all i want is the ecm configured back to stock, was told by the service department that when getting the download from harleys site they have to punch in the vin # for the correct flash for the ecm and if the tech put wrong number in that could be why i got a flash for a 2007 and not the 2006 that my bike is, the ecm's are the same for 2006 and 2007 they didnt change them till 2008, i will let you guys know what happens
went to the dealer this morning with the bike, after checking it they said the tech that worked on my bike somehow put the wrong vin # when doing the download so the ecm was back to stock, they installed the right vin and did the download to configure the computer back to stock and everything is fine now, when i got home i hooked up a sert i have and read the vin in the ecm and it matches the bike.
