Spark Plug color
RE: Spark Plug color
You cant really tell that way, the front cyl runs richer at idle because of the way the stock exhaust is made. To get a correct plug reading,Put in a fresh set of plugs and run bike around for awhile at good speed, interstate or other take it to 60-70 and cruise for a few minutes then kill engine and coast to stop. Now pull plugs and go by color. This is the only waty to get a correct plug reading. Just another note, you may have more of a white plug than tan due to the gas additives used today.
Thanks for the info. This is what I didso far. I installed the Fullsac Kit and a new set of stock HDplugs just like the ones I removedto see ifthe Fullsac system makes a difference. I haven't had the bike out yetbecause it snowed hereFriday andyesterday All I can do know ishope the snow (apx.10") melts fast so I can take the bike for a ride and see if this changes anything.
[IMG]local://upfiles/16240/114361EE9D9A4203B5A7DB7DA0D93D38.jpg[/IMG]
I switched from the HD Platinum plugs to NGK Iridium plugs last summer and have had no problems with lean/rich discoloration of the plugs. Not sure if its the new plugs or me driving like a madman...[:'(]
Anyway, the bike seems like it has more power and getup-n-go with these new plugs.
Here is a good link for sparkplug reading -
http://www.dansmc.com/Spark_Plugs/Sp...s_catalog.html
But it is difficult to get a good reading on the plugs with all the additives in the gas now, but it will give you a general idea of how you are running.
Steve
Steve
I took the bike out last weekend and did close to 450 miles, (I installed a new set of stock HD plugs)I pulled the plugs and they look clean and white no deposits . No color change from new. What do you think? MPH was 42 bike runs great as it always has (5,200 miles) I found this pic of someone Else's plugs, and this is what mine look like
ORIGINAL: ricaroo
