Service manual has not arrived yet, please look up oil amounts?
It should be in the owner's manual that came with the bike.
If you don't have the owner's manual add oil til you hit the full mark (between 3 and 4 qts).
My 09 says 3.5 qt then run engine and check oil hot. Add as necessary to top off but it's a 96" motor and may not be the same.
I run mine about 1/2 qt low.
Out of the 2014 Trike owners manual
Engine oil with filter* 4 qt
Transmission** 1qt
Primary (approximate) 1.4qt
* when refilling, initially add 3qt and add as needed to bring level within Specifications
** when refilling, initially add 28oz and add as needed to bring level within Specifications
Transmission** 1qt
