Rivera clutch?
Rivera clutch? UPDATE!
I believe I burned up the clutch in my 2011 Limited after 24,000 miles. I found a clutch kit by Rivera, one extra clutch plate, ten percent stronger spring. J & P part # 630-338 Primo mechanics choice extra plate clutch kit. I have 255 cams, ride two up, and figure the way I ride, the extra holding power is needed. Input?
What makes you believe you burned it up?
I agree with everyone else -- I'd
try adjusting first -- then if that does not work I would look into AIM products --
Adjustment
I will pull the cover and check the free play. It slips real bad, won't hook at all in third or fourth on a power shift. It did show up right after I had a new rear shift lever installed, which requires the chain case be removed, clutch etc. I sure hope that is all that is wrong. If it isn't, the severity of slippage would mean it is seriously hurt. I vaguely remember last summer it didn't lock instantly on a WOT 3 to 4 shift,,,,,,, very slight delay.
