For all you Ohlin fan(atics)...
http://www.roadrunner.travel/2013/12...ouring-models/
Ohlins now has front fork kits for Harley touring bikes. Ignore the price, I'm sure this will be a must-have item for the ultimate tourer.
I love my rear Ohlins, but a simple drop in cartridge does nothing for the sorry *** fork triple tree and clamp design of 2013 and prior models. Flexing and twisting of the front forks cannot be fixed by drop-in cartridges regardless of who manufacturers them.
Howard is supposed to be working on clamping and a real adjustable front end, but he is taking a long time to get it done.
The larger front fork diameters and new clamp design in the 2014's addressed the poor design that was ignored for years by HD.
I'm hoping Progressive comes out with Monotubes that will fit the larger forks soon. If not, it'll be back to the HD alter with money in hand.
Progressive mono tubes are completely different, they are tiny gas pressurized shocks that install inside your forks. The Ohlins is a damping cartridge that sits inside the fork tube in an oil bath. I do not know the specifics but I'd guess the Ohlins set up uses 4x the oil that the Progressive does and you can change oil levels, oil viscosity and adjust compression and rebound damping. The Progressive monotubes offer none of this type of adjustability. 2 completely different products.
The Monotubes are a HUGE improvement over the stock internals, but they're still a one-size-fits-all approach to the problem. The Ohlins cartridges would appear to be a far more tuneable solution, with a setup like Howard's working on being better still as it can be adjusted with the cartridges still in the fork tubes.
And yes, none of these address the clamping issue. For that, you have to go with the CCE or wait for Howard to finish testing his solution.
