Can you tell difference between ABS and Non-ABS by looking at them?
Looking to buy a set of Agitator take-offs which guy said came off a 2011 CVO Road Glide with no miles since titled. Guy said they have non-ABS bearings. I thought ABS was standard on all the newer CVOs. Is there a way to look at the bearings and tell when the are still pressed in the rims?
Thanks in advance.
Thanks in advance.
Item 8 in the attached pic is the ABS sensor as you can see it sits directly over the bearing.
the ABS bearing is thicker, and has a very specific look to it. ABS is on the left in photo
go here
https://www.hdforums.com/forum/touri...-bearings.html
go here
go here
go here
The ABS bearing seal is grey, the non-ABS bearing seal is black. This is when they are installed so I am talking about the outer seal that you can see when the bearings are installed in the wheel. I just went through this about 2 weeks ago.
If you have ABS and DON'T have a fender light you will have 2 cables/wires running to the front wheel on the left side of the front wheel. With a fender light, there are three but the fender light wire feeds into the side of the fender. Also, the hub on an ABS bike is black. But the cables/wires count is what I used to tell when I was looking at used bikes...... You would think sellers would mention it but you'd be surprised at how many had ABS but it wasn't mentioned in the ad.......
