Dealer will only install SE Cams
Old 12-10-2013, 02:27 PM
2013_FLHTK's Avatar
2013_FLHTK
2013_FLHTK is offline
Received 1,043 Likes on 258 Posts
Originally Posted by UltraNutZ
just be careful with head pipe selection because they are not all created equal. The ones that I see that seem to work very well repeatedly with a semi-stock setup are fullsac and jackpot.
I'm going with S&S Power Tune Duals. The tech loves them because of fit and finish and they are easy to install. The tuner loves them because of the 12 and 18mm bungs on each pipe. Perfect setup for their DYNO.
  #32
Old 12-10-2013, 02:30 PM
UltraNutZ's Avatar
UltraNutZ
UltraNutZ is offline
don't know anything about them but as long as they like and recommend them you should be fine.
Not sure what tuning device you're set to use also but if you are given a choice between the HD street tuner and the HD SEPST, go with the SEPST this way you can tune your own bike (or have someone other than dealer tune it) later on if you change things up
  #33
Old 12-10-2013, 02:34 PM
XARAN's Avatar
XARAN
XARAN is offline
Originally Posted by Beav
SE 254e...
Compliant, AND happy.
per the SE catalog SE 254e are "race only"
http://viewer.zmags.com/publication/...d#/f935f2bd/48
  #34
Old 12-10-2013, 02:35 PM
2013_FLHTK's Avatar
2013_FLHTK
SEPST is my choice as well as the dealers.
  #35
Old 12-10-2013, 02:37 PM
XARAN's Avatar
XARAN
XARAN is offline
+1 if you are going to use the HD Tuner use the SEPST I would not even waste the $ on the Street Tuner, it is way to limited in what it will do and you will still be very lean and possible have heat issues.
  #36
Old 12-10-2013, 03:21 PM
equandt's Avatar
equandt
equandt is offline
Of the SE cams the SE204 would give you good performance that you would be pretty happy with. Average numbers would be low 90s for hp and low 100s for tq with a good intake and exhaust.
BTW the SE204s sound fantastic.
Good luck.
  #37
Old 12-10-2013, 03:29 PM
SBates08's Avatar
SBates08
SBates08 is offline
Received 1,239 Likes on 1,002 Posts
According to some of the BS about warranty that some have stated in this thread the SEPST should void the warranty as well because its "For Race Application Only". But we all know it won't. Just as the dealers and MOCO know aftermarket cams won't void your warranty either. It's pure propaganda to push their branded parts on you. Scare tactic......plain and simple.
  #38
Old 12-10-2013, 03:36 PM
Mike's Avatar
Mike
Mike is offline
Originally Posted by 2013_FLHTK
Do I simply cave to their limitations?
Should I skip the cam change?
Did I make a mistake getting the extended warranty?
grab some wrenches, and the service manual and install the cams you want in your bike. Take the money you save and pay for a dyno tune. win-win
If you're stuck with SE cams, the 204s are a natural drop in for the 103 motors, and work as well as a lot of aftermarket cams.
  #39
Old 12-10-2013, 04:02 PM
'05Train's Avatar
'05Train
'05Train is offline
It absolutely will if the dealer decides not to cover it.
Good luck with that though.
  #40
Old 12-10-2013, 04:32 PM
skratch's Avatar
skratch
skratch is offline
Received 4,357 Likes on 2,536 Posts
one thing to consider. your factory warranty runs for 2 years. the magnusson moss warranty act covers that. when your factory warranty expires, and you are being covered under the esp, then all bets are off. it is not a warranty, it is a service plan, aka an insurance policy and they can deny coverage for whatever reason floats their boat and mag-moss won't mean a hill of beans then.
Quick Reply: Dealer will only install SE Cams
