Dealer will only install SE Cams
Using this logic, do absolutely nothing to your bike! As soon as you ride off of the lot with those shiny new true dual headers and slipons, your warranty is null and void. I don't think so......I haven't seen a list yet that shows what is and what is not the stuff that will void a warranty, other than proof that it was the "aftermarket" part that caused the failure.
Again, I refer you to the Magnuson-Moss Act. Keep in mind, nobody said that if the stuff hits the fan that there won't be fight, but this is definitely in the consumers corner.
And remember, opinions are like a**holes and elbows, everybody has at least one.
Do whatever it is that you want, it's yours! Good luck to ya! I'm out.
Further, unless your Stage 1 is comprised entirely of parts that carry an EPA stamp, you're in violation of federal emissions laws, and you're running parts that are labeled "for off-road use only". Why should Harley warranty those parts, or any part connected to them?
It'd be great if people would just take responsibility for themselves instead of looking for someone else to pay for their broken stuff. Your warranty covers your stock bike. If your bike isn't stock, don't be surprised if your warranty claim's denied.
Now with all that said, it sounds like this particular dealer only wants to sell Harley parts. That's their right, and it should give the OP an insight into what they intend to cover under the warranty.
OK, cutting to the chase here.
I got the 7 year extended warranty on my 2010 FLHTK because I ride it on my commute to work. I roll up about 15K miles per year, same as what OP is planning.
Dealer installed 255 cams, SE air cleaner, SE Fatshotz pipes, which are now covered under the ESP. I kept the headpipe and cat to keep things covered by ESP.
I had the bike tuned by an indy, she runs pretty cool for having the cat in the headpipe.
Nearly 4 years into the 7 year ESP, the bike has 61K miles and the ESP has paid for itself. From my perspective, things worked out very well. I still have coverage on the stage 1 stuff, the bike runs cooler and better. Is it a perfect situation? Nope. But it is the best I can do.
So, if you want peace of mind, stick with HD parts that will be covered under the ESP. Get the bike tuned well, then ride it like you stole it until the ESP expires.
I figure by the time my ESP runs out I'll have 110K miles on the bike. Not a bad deal for me.
The Magnuson-Moss Act does allow parts to be replaced with aftermarket parts. It does not cover parts that modify the engine in any way. If you replaced the cams with a factory profile but from an aftermarket supplier you might have an argument if the warranty was voided. But installing higher lift or different duration cams is modifying the engine and is not coverd under the Magnuson-Moss Act.
The service department called back and offered 20% off all parts and labor as well as half off the DYNO tune. As someone said in an earlier post. This has more to do with their policy than it does with my ESP. I may cave if I can get them to knock off another $200 off the total price. As a newbie I thank you for your prompt responses.
Someone mentioned a blower. I would bet large amounts of cash that the second they find out you have placed a blower on an engine that the warranty would be canceled. It wouldn't surprise me in that case it ALL warranty coverage would go away.
05 Train summed it up pretty well IMO. In my experience it is most important on warranty issues that it is up to the dealer, they can sneak a lot by if they are on your side. Bottom line is any modification may cause you a problem if there is a failure and they link it to the modification which is why having a good dealer on your side makes a big difference. The MM Act offers some protection but in the event that they deny it means court time and in most cases its not worth it and /or they will win.
