A mod i came up with some might like?
Old 12-06-2013, 11:16 PM
hanny's Avatar
hanny
hanny is offline
Default parts needed to do the mod
you need one of these
http://www.ebay.com/itm/12V-24V-Mini...item460ffb5bde
and one of these
http://www.ebay.com/itm/Hopkins-Mfg-...item19e5e983a1
Then just simply wire the volt meter into the line, solder and put shrink tube over it. when you hook it up to the bike youshould see voltage, if not then flip it and use the other end. Then mark that end so you don't have to do it again. paul
Old 12-06-2013, 11:20 PM
hanny's Avatar
hanny
hanny is offline
Originally Posted by bigdaddy33
+1 Same thing's happened to me. Tender shows solid green but the battery is toast. Your voltmeter is a great idea. If you decide to sell them, shoot me a PM. For the right price I might be good for three.
Originally Posted by wpdjoey
Great idea
Originally Posted by titched
Great idea! PM me and let me know a price. I think u have to make an assembly line.
Originally Posted by Teardrop
How about posting where you bought the volt meter at? Great idea!
Originally Posted by Diggman
Two wire voltmeter? Tapped into the tender line?
How about a simple schematic?
Diggs
Originally Posted by cdestuck
eBay. Search for digital 12v volt meter. Under 8 bucks shipped
check out post 21 for the stuff you need to do the mod, paul
Old 12-07-2013, 12:13 AM
skratch's Avatar
skratch
skratch is offline
Received 4,357 Likes on 2,536 Posts
having been in the situation where a tender 'looked' like it was doing it's job but killed my battery, i think this is a great idea.
how about a pic of how you wired it up?
Old 12-07-2013, 12:55 AM
DeJavu's Avatar
DeJavu
DeJavu is offline
I have a cigarette lighter socket mounted by my key switch wired direct to batt. I can check voltage, charge batt, hook up tender, charge my phone and even light a cigarette. Super handy!
Old 12-07-2013, 01:03 AM
Bikeagraman's Avatar
Bikeagraman
Bikeagraman is offline
Thanks for the great idea, hanny! Although I haven't run into the same situation that prompted your invention, I know it's only a matter of time that I will. So I just ordered the items you mentioned and will work on hooking them up when they arrive.
Old 12-07-2013, 04:47 AM
craving94509's Avatar
craving94509
craving94509 is offline
TIA,
Diggs
+1 could you scratch out a simply schematic for the electrically challenged? I understand cutting off the cigarette adapter and using the pigtail connector.
Beyond that I am lost.
Appreciate any help.
Old 12-07-2013, 06:05 AM
craving94509
Hanny,
Does the second pigtail connect to the same point as the first as illustrated below? Or does the second pigtail connect to different terminals inside the meter?
Old 12-07-2013, 06:15 AM
SeeJeepCrawl's Avatar
SeeJeepCrawl
SeeJeepCrawl is offline
and one of these
Thanks for sharing. Awesome idea.
Old 12-07-2013, 06:55 AM
Rider1973's Avatar
Rider1973
Rider1973 is offline
Default About that Plate cover?
So did you have the Yaffe Plate cover custom painted, or did you buy it that way? I see nothing on their site.
Thanks in advance.
Old 12-07-2013, 06:57 AM
1st 96 ultra's Avatar
1st 96 ultra
1st 96 ultra is offline
have not seen one but normally the volt meter is just hooked in line so you get the voltage reading , the wires do not run through the meter
Quick Reply: A mod i came up with some might like?
