RK tour pak lights
RK tour pak lights
SOoo I have been searching the forum about the Tour Pak...I have a '05 RK Tour Pak that I would like to add lights to...found LED light bar on eBay for 100 dollars but it says stop/run only...I don't want to spend alot of cash. I believe the HD ones come with stop/run/directionals....but does anyone know if there's an OEM unit that does all three.
I may be mistaken about the eBay ones but that's what they claim stop/run...no directionals.
http://www.ebay.com/itm/Black-ABS-LE...cc4553&vxp=mtr
Received 49,988 Likes
If you have the Tour Pack with the liner in it already the standard HD Tour Pack light set up will not fit unless you remove the liner. I have read some reply's about the "Knock Off" light bars on E-Bay and some say that the fit is less than perfect. It's wintertime in your neck of the woods and a trip to a swap meet might be in order. As far as room loss inside the Tor Pack it really is negligible and I wouldn't let that sway your choice.
technically none of the tour pack light kits are RTB. I just bought that same light kit for my EG. What you need is a RTB module for the bike, (custom dynamics sells these) and then simply splice into this harness. Its a very simple task and i can walk you through it if you cant figure it out. I went to home depot and got some wire and made my own harness. 4 wires total with some posi taps. 5 minute job.
You can check out this thread showing how I added lighting to the back of my Limited. Did it a year and a half ago and still works great. Nice and bright back there and not real expensive. Does running and brake. Custom dynamics sells a version with yellow ends that will work as turn signals as well, but I didn't want that.
https://www.hdforums.com/forum/touri...-installs.html
