Monkey Bars
Do it yourself. The 14's have if I remember correctly 5 wires on the left controls and 7 on the right. Thats around half of what they use to be and makes it a lot easier getting the wires through. My advise would be to have someone help you when you are running the wires. One pulling and the other person pushing and use wd-40 on the wires as lube.
Sounds like 10s would be ticket for you. It's pain running wire bundles on right side but it's doable with little patience and plenty beer afterwards . I only had to run +4 clutch cable everything else reached ok. I've read some post saying '14 clutch brake cables ok. The Yaffe instuctions are pretty good give it a shot we'll give u moral support!
I think I've wired 4-5 sets of these bars, but all were for pre-14 bikes. Hell, I even had a forum member mail me his bars so I could pull his cables, and we've never even met! On those bikes, with cruise, the throttle side has about 20 wires and the clutch side has 12.
On the 2014 bikes, it's going to be much easier.
The trick is that you don't pull the wires through as much as you push them. I started out by dropping a small chain through the bars, attached to a 3/16" vinyl coated cable. I attached that cable to the wires (which are all bundled in heat shrink), and you push them in, then pull them, repeating the process until they're through.
It's really not a tough job at all. Use conduit lubricant too, it's not oily, and cleans up easy.
There are 4 wires on the left control and 5 wires on the right control. Then you have your twist grip sensor wiring that has wiring for heated grips also. I removed the heated grip wiring on mine during the install.
I got the Yaffes pre-wired with all Chrome controls from HC Customs. I read alot and did alot of research. Most dealers will charge 8-10 hours of labour just to install and wire because of the 90 degree corner. I bought the 12" bars, all chrome controls ready to install for $1200. Installed them with a buddy in 3.5 hrs. Hardest part was the clutch cable. You'll need some expertise around the mechanism there. Other than that works great.
I am 6'3'' and the 12's are perfect. They come about 2.5" above the fairing but I wanted to be able to actually "see" the bars from the front as well as use my stock mirrors. With 10's you lose vision out of your mirrors so you'll have to find another option.
For the record, I had no issues with HCC. They shipped out fast, and everything came in perfect condition. Hope this helps. I know where you are in making this decision.
PS....I know....the grips!!! Still looking for the "right" set.
Yeah that
I have 14" Monkey Bars on my 2001 Road King and am about to upgrade next week to a 2014 SGS. I am putting 12" Monkey Bars on the new bike, and was quoted 4.5 hours of labor from the dealer. 10 hours of labor seems really excessive. The guy who wired my 14 inchers did it in 2-3 hours. Just throwing it out there.
