Where are you guys mounting them? Are you sticking them to the frame under the tank?
I'm also thinking I'll add them to the saddle bag lower support tube.
I typically do not tell people to search the forum. Some people get bent out of shape and are badged search police - I'm not that guy. But, I'll recommend searching this one not to be an A-Hole, but to say I'll bet you'll find a lot of good info.
With that said......
I put them on the frame under my tank (didn't want problems with lights if I pull the tank)
On the front fender, in the angled mounting piece, right where it bolts to the forks.
Under the driver's floor boards (felt like it would through the lights out further than under the fram)
Behind motor where spark plugs plug in
Under throttle body
In the skull horn
Under saddlebag rails
Reason: add pics
I put some on both front calipers, under tank, under frame, behind engine, inside of swing arms, and under saddlebag frames.
+1. When I head to work in the dark each morning, the entire lane is lit up while on the highway. The ones on the saddlebag frames, I angled out a little bit to give me more light coverage on the ground. I got mine through Rumbling Pride, located in Florida. They are a great company to work with and stand behind their products...great customer service.
