U Bolts for additional saddlebag security?
Isn't your bag rear mounting ear welded to the metal support frame like my RKC? The front mounting ear is held on by a 7/16 but they can only get that one.
On my '00 they bolt on.
Sorry about your bags. Thieves are looking for easy targets. I think the Brukus or similar setup and locking your bags is all ya need. They can't just pop them off from the out side so they move on. If they are gonna jimmie the locks and mess with bolts ya are screwed anyway. But it would be easy to drill a couple holes and put a u-bolt around the lower rail if that will ease your mind.
By changing the twist pins HD uses to any screw & nut assembly, you have removed the ability of a fast grab by a skilled thief using a screwdriver. If they have to pry open the lids to get the bags off, 99.99% won't bother because time is the enemy of any thief. Also, replacing the twist pins with screws eliminates the possibility of the pins popping off while you're on the road.
I replaced my pins with buttonhead allens ( so you can't use pliers to get the bolt out) & a u-nut assembly shortly after I bought it in 06. I also replaced the bracket bolts with allens just to make sure it wasn't coming off easily. I never gave it a second thought afterwards .... My 2 cents worth.
+1, I agree that changing the fasteners to a nut bolt like Brukus is the overall best solution. Thief s are looking for the easy target and if they cant pop the back tab off and run chances are they will move on. Of course there is always the one that will try to pop the lids or more and then chances are the damage to the bags will cost as much to repair or replace as if they got the whole bag.
So you are kind of dammed if you do or dont.
It does seem to be a growing problem in So Ca, my dealer Antelope Valley HD had a set stolen in their parking lot a while back
