Progressive 412s
Progressive 412s
I've done lots of searching here, Google and on other sites about which Progressive 412s to order and still haven't been able to come up with a clear answer. Heavy duty or standard springs and 12.5" or 12". I'm 220lbs and ride solo 95% the time. I'm leaning toward standard springs and 12.5" for the extra 1/2" of travel and don't think it should change the look of the bike if anything at all. If I do throw a passenger on for a joy ride I can crank them down all the way and the extra 1/2" of travel will also help. Am I thinking wrong? I'm placing an order tomorrow one way or the other so I've got to figure it out. I think I'm going to call Progressive in the morning to get there input.
Get the 12.5 412's. Get the standard duty. Click them up to the second setting. They will work perfect for you, and as long as the passenger isn't TOO heavy, you should be fine. If you want to set them once and never touch them again, even with a passenger, set them on setting 3 (middle setting). Not quite as smooth, but still way better than the stock shocks, and a passenger can hop on any time without bottoming out issues. Frankly, 13's would be the best bet, second setting and your done (forever), but you only wanted the 12.5 shocks.
I talked to Progressive and the tech said definitely the standard springs. He said the HD would be too stiff when I ride solo and when I put a passenger on I could crank the standards down and be fine, unless it's a 300lb bearded lady but that would be a whole other problem.
