Tender install???
Red to pos. & white or black to neg on the battery. Avoid, by all means, running the harness over the the seat bearing area, as 0NEDOWNAND5UP posted.
I have mine cable tied very tight to the frame down tubes on both the Dyna & the bagger with black ties & you can't see it there unless you are looking for it.
The 3 vertical wire looms, the battery tender wire is the right most one, the narrow one with the flexible black conduit. I then looped up the excess wire, ran it under the battery box to the right side cover area (left in the photo), tied it off to an existing wire so the end stuck out where it was accessible and secure. Make sure you put the tender wire ends between the battery cables and bolts and not between the cables and battery, or you will not get a good ground.
I ran the pigtail for the heated gear from the battery toward the rear of the bike and I bring it up through the left hand side of the slot in the seat where the driver's backrest would go. I have the dual controller clipped on my jacket pocket and I just reach around to connect to the pigtail behind me. I also put a "Y" connector onto the end of the pigtail so I connect a passenger's gear. When not in use the wire just sits in the seat slot.
