Anyone de-badge their Gas tank/2014 FLHTK
Old 12-01-2013, 08:31 PM
gotwages's Avatar
gotwages
gotwages is offline
WD-40 and some fishing string. Done.
Attached Thumbnails Anyone de-badge their Gas tank/2014 FLHTK-image-724680166.jpg   Anyone de-badge their Gas tank/2014 FLHTK-image-694323875.jpg
  #32
Old 12-01-2013, 08:59 PM
Brykwil's Avatar
Brykwil
Brykwil is offline
Originally Posted by xhere
Was thinking of taking mine off...Any tips in doing so? So I dont damage paint, lol
Post up some pics if you end up removing them.Please
  #33
Old 12-01-2013, 09:08 PM
Brykwil's Avatar
Brykwil
Brykwil is offline
Looks good.
  #34
Old 12-01-2013, 09:09 PM
xhere's Avatar
xhere
xhere is offline
I will get them off this coming week and will get them posted...
  #35
Old 12-01-2013, 09:20 PM
xhere's Avatar
xhere
xhere is offline
Nice clean look!
  #36
Old 12-02-2013, 05:42 AM
Gunnysgt's Avatar
Gunnysgt
Gunnysgt is offline
I've taken badges and emblems off several bikes using 8 lb fishing line and WD-40, ONE CAUTION, do NOT use a fast sawing motion when using the line, it can generate friction and damage the paint. Slow and steady works, I spray the WD over top and let it soak in a bit, then start with the string. The best stuff I ever used to take off the remaining sticky was 3M wax and adhesive remover but for some reason 3M just discontinued that product. Check with your local auto paint store and see what they suggest to remove sticky with no paint damage. I have used Lacquer thinner as well.
  #37
Old 12-02-2013, 07:24 PM
iglideUC's Avatar
iglideUC
iglideUC is offline
Originally Posted by offthewall
What is that chrome dress strip on your front fender where the model name badge was?
fender badge off of a 2012 limited.
  #38
Old 12-02-2013, 07:54 PM
Lucky Doug's Avatar
Lucky Doug
Lucky Doug is offline
I took the badges off Bob. Too much fading in the paint so I had to put it back on. Kind of gotten used to it now.
  #39
Old 12-18-2013, 12:22 PM
Silvio's Avatar
Silvio
Silvio is offline
Originally Posted by CaptainKirk
Heat and fishing line along with a second set of hands. Take the gas cap off in a well ventilated area. Take a good hair dryer (shouldn't need a heat gun for this) and heat the area where the emblem is. While gently pulling the emblem away from the tank, use the fishing line like dental floss to get between the glue and the paint. Now I used this on a white bike which was pretty forgiving as far as marks go but I think this is the safest way. Don't be in a hurry. I also used goo-gone with no damage to the paint. Only goo-gone though...... Hope this helps....
Why remove the gas cap?
  #40
Old 12-18-2013, 01:13 PM
CaptainKirk's Avatar
CaptainKirk
CaptainKirk is offline
You're going to be heating gasoline in an enclosed space. Not "sure" it's necessary but I'd rather not have pressure building up in the tank from an accidently overheated tank. I know it does in the sun and it's vented but still......
Quick Reply: Anyone de-badge their Gas tank/2014 FLHTK
