Upgrade advise!
If those are TW-408-6 cams with 10.5+ compression and matched heads It ought to rock! Good Luck!
I put auto ACR's in the heads when I had it ported, so that's not an issue.
I believe they are TW-408's I'm just a motorhead dummy!
I'd like more information on the 2:1:2 exhaust, interesting.
Historically, traditionally, Harley used a 2-into-1 long before they went to 2-1-2. Jus' sayin'.......
Not sure I've read one good post on the SE lifters, I would highly stay away from those. I think I have them in my current engine and plan to replace them with the woods lifters I have in my other engine.
If you haven't bought the cams yet why not go with some that have been tried and true in 107's? Have you looked at the Fuel Moto web site and checked out the dyno numbers from there 107 set up, normally with woods 555 or 777's.
Polishing the 50mm throttle body will give you very little performance gains, I guess it would depend on the cost to have it done if it would be worth it.
I like your quote, that's funny, but in reality I already have $800 bucks in the tuner.
ARCs are great!
There are two TW-408 cams, bolt in 44 and hot 6. 44 would not be a good choice but the 6 could rock! May be noisy with .650 lift? Roller rocker territory. Some intake porting may be in order with that cam combo.
http://www.fuelmotousa.com/harley/en.../tw-408-6.html
Factory 2-1-2 showed up on the '09 tourers. Fuelmoto, Fullsack, Vance&Hines have excellent performing 2-1-2 (X) headers.
Well I will have a little extra change in my pocket come January, with that said, I'm thinking about going from a 2009 96 to a 107.
currently I have already had my heads worked on to 10.1. polished and ported.
Ventilator air cleaner.
T-Max
Adjustable pushrods.
Rineharts true duals, with 3-1/2 pipes.
SE 255 Cam.
So here is what I want,
SE 259 cams.
SE 107 flat top pistons.
The guys who did my heads will bore the cylinders to 107.
This is my question I don't know about.
Will I need to get different injectors for the 107?
Will polishing the 50MM TB be worth the cost?
And how bout those SE Lifters? will that make a difference?
T-Max
SE 255 Cam.
SE 259 cams.
Any more than this and you are going to have issues with clutch and possibly crank stuff. Over 115 hp and you can look forward to issues. I know there are lots that have way more than this that will challenge that statement.
Gee, don't know what to say!
Lots of great information posted here, I just want to thank each and everyone of you for taking the time to give your opinion.
Again thanks all, my motor guy and I are going to have a conversation today about these otions.
He is a respected motor builder in Central Indiana, knows what he is doing.
Nice! Keep us posted. Would love a dyno sheet but know we won't get one since ya have the Thundermax.
