New Mufflers 2014 SGS
Like most new '14 SGS owners ... looking for a replacement set of muffler pipes/slip ons to give it that Harley sound. Although I don't think stock is horrible, still doesn't have the rumble I want.
I have read if you just replace the mufflers you don't need the electronic gizmo for an additional couple hundred bucks to regulate the exhaust compression. Is that true?
It also seems pretty simple..remove a couple bolts, slide out mufflers and install the new ones...
Anyone have any recommendations for the '14 SGS .. tips .. etc.
Much appreciated.
Much appreciated.
There are tons of "slip-ons" or "pipes". Depends on looks and decibel level that is to you liking. Read around on these forums (search). You will get a good idea of what you like. I think your going to find you want more than just a slip-on. Read about the OEM header that is on your bike. It is restricting the sound also.
If I can make a suggestion that you will find on many postings here on the same subject, go to a few rider events and listen and ask what hey are running.. Each has a different sound and it's what your looking for, not what someone suggests is good. Personally I would not do just slip on's, as many have done as well as I, get rid of the stock head pipe.. So much different in many ways......performance, heat and sound...IMHO
