Hot Oil
Hot Oil
I haven't posted in a long time. Thinking I'll get back into this. I crashed a 2011 Street Glide and pretty much knocked me out for a year but I'm back and riding the same one I crashed. Last month I'm on I95 in central florida it's about 85 out and there is a crash about 10 miles ahead and I missed the exit to get off. So I'm stuck in 3 to 5 mph traffic for what seemed like forever. I have an oil temp gage and I seen higher oil temps than I ever have seen, 285 and a little higher. I run Amsoil and everyone says nothing bad happened to the oil but man was it HOTTTT. So I got to looking around and Jagg makes a powered oil cooler (has a fan in it) and then found the HOT JUGS website were they blow air across your cylinder head. Anyone had any experience with either of these products???
A lot of the members here are using these...
http://www.wardspartswerks.com/cooling-fans-2.html
and they swear by them. I'm saving up my $$$ so I can get me some!!
Also, if you do add a oil cooler, you can get a different thermostat for it from Jason as well. I got some different thermostats from him not to long ago, and they work just like he said they will. As he says, it's better to get a jump on your high temps, than to start trying to cool the oil after it reaches the so called "normal" temp of 185.
http://www.wardspartswerks.com/thermostats.html
Vnots that's what I was hoping for from the post. If the forced air oil cooler is going to lower my oil temp to under 240 at idle that would suit me but I can't find any info on what to expect if installed. the cylinder head fans look interesting especially the ones that xwhyz1959 mentioned. they look a lot better than the hot jugs one I looked at. $269 aint bad either.
Exactly. The temps the OP mentions in traffic are not bad at all and if they are accurate, then consider yourself fortunate that they did not get any higher.
Cylinder head fans help keep your engine out of heat management. They do little for oil temperature. A fan equipped oil cooler will cool your oil a bit, but does little for head temperature. If you want to address the heat issues of idling in traffic, I would suggest both. The bottom line is that if you stay in traffic long enough, you will melt down your engine no matter what you do....
