Brake lights stay on
2008 FLHTC my brake lights are staying on if I hit the rear brake I hear a click sound by the battery and the will go out but come back on again if I keep tapping on the rear brake sometimes I can get them to go out. When they are out and I hit the front brake they come on and go off when I release it. Then if I hit the rear sometimes they come on and go bake off and sometimes they will not go off. Any Ideas? Think the rear switch is bad?
wd40 is not a contact cleaner.
spraying a lube into any electrical area will just hold dirt in place.
contact cleaners are available at any electronic store- make sure to read the label...some are not to be used around plastic or painted parts and will really make a mess if mis-used.
OP, test your rear brake light switch- likely the problem.
test it with a meter, in place
diagnose before you start replacing parts....be aware that IF you have had your hand controls loose with out shimming the switch it can break.
it is unlikely that the relay is bad, but that is possible.
most automotive relays are rated for 100,000 cycles.
I have never had one fail on any of my vehicles ( about a dozen), but it can happen
mike
mike
