Is it Excess or Personality
I started with a 2008 FLHTCU 105th Anniversary Then I change a few parts so here I go ZIPPER Thunder Max TBW ECU with Auto Tune, H/D-SE stage 1air cleaner kit & Zipper Flox Max high flow air filter, Jagg 10 row oil cooler with oil filter adaptor with thermostat, S&S underslung Power Tune Dual Exhaust Header pipe, Rinehart high flow 3.5" outlet& 1.75 inlet mufflers, S&S 551 camshafts, H/D-SE cast flat top pistons notched for valve cleaners, Bored cyl. to 103ci to match piston fit, Head Work enlarged intake & exhaust valves, competition valve springs, Port work to match system, H/D-SE adjustable pushrods, Corbin Saddle Classic Solo & Pillion seat front backrest & custom made tour-pak backrest with shorter arm rest to my liking, H/D Air Wing Tour-Pak luggage rack black, Aux Plug wired in tour-pak, H/D detachable two up Tour-Pak kit & detachable solo rack chrome, Tour-Pak wiring is all on plug for easy dismount & mounting, Flanders Handlebar TBW black E2 Tall Ultra Classic 1" style punched holes for internal wiring, H/D black mirrors, H/D black clutch & brake levers, Heat Demons handlebar grip warmers inside tube heaters Four Way LED switch black, Kuryakyn black ISO grips & throttle boss, Klock Werks Windshield dark smoke 8.5" Flared, J&M 7.25 three way fairing speakers kit, J&M Flexpower CB inner fairing antenna, J&M Flexpower AM/FM/WB inner fairing antenna, Kuryakyn fender tip LED marker light with curved license plate mount, H/D rear running-turn-brake light controller, H/D smoked turn signal front lens& chrome lens ring covers, H/D Street Glide rear foot peg mount & peg. H/D Engine guard highway clamps mount with pegs, Metzeler 880 tires. That is all I have done to my stock bike BUTT I NEED to CHROME the front end thats for Personality???????? say ya or slap my hand
Received 74,920 Likes
